Hey guys, I have a question about grounding a hot tub, heres some info.
We are roughing in a house with a garage 200A service. The owner is installing 2 hot tubs. They say you have to have a seperate ground for the motor casing...
My question is, do I have to run that ground all the way back to the main panel where the motor is fed from (150' Away), or can I ground it to the main water line? (30' Away).
What does the current NEC Code say? Can you please include Article #'s.
Thank you!
Thank you!
