Hello, this is my first post so forgive if i ramble a bit as i am new here.
I am wiring a 3 phase delta wye transformer that has a copper bonding strap installed from the manufacturer. I installed a double lug and bolted it to the cage and terminated the grounds from the primary and secondary in this location, I then put a double lug on Xo where i terminated the secondary neutral and the bonding wire i brought to the building steel.
Question, is this correct or should i have terminated the primary, secondary grounds AND the bonding wire i brought to building steel under the same lug and brought a jumper from said lug and connected that to the X0?
