1 - 2 of 2 Posts
I have an application where a solar panel (DC Voltage) will be on a pivoting system. It pivots on bronze bushings (Conductive). Is there a code that says these bushings cant be a grounding system, and that I have to install jumper wires from the pivoting solar panel to an earth ground.
Please point me to the NEC code if you can help.
Thank you very much.
1 - 2 of 2 Posts
