Roger: The building structure was used as a reference point.
Bad: The specs didn't call out to increase the wire size after 'x' amount of feet. The panel schedules however called out for #12 AWG. Before installation we contacted the engineer and they said that each gfci receptacle will need a dedicated circuit, neutral and ground. As well as an additional equipment grounding conductor used just to bond at all junction boxes. We asked, since there is an additional ground in the pipe then we need to install Isolated Ground GFCI receptacles? Engineer's response was no, IG GFCI receptacles is not necessary.
