ARe you allowed to raise the inside plate above the factory setting screw if you are installing r30 bulbs? My boss says you can't and the inspector can fail you. I have been raising them for years at my last job. I mean raising the plate all the way up and securing it with a peanut screw and putting in r40 65 watt bulbs with no problem,even though that approach isn't right..
