1 - 20 of 50 Posts
Can someone give me a rundown on how homes are wired in the UK? It seems to me that all recessed lights and fixtures are cut into the drywall on the finish. Most all of the high end electrical fixtures from UK manufacturers do not have a "rough in housing".
Pictures would be great.
· RIP 1959-2015
That's a good way to drive up the cost of the job.
Yeah, I basically found the fixtures the lighting designer from the uk specd and found stuff that was made here. But even looking online it looks like all recessed is cut in after drywall, and the fixture boxes are all surface mounted.
· Banned
For starters, it's nothing like North American wiring. :laughing: They use 240 volts, ring circuits and fusible plugs, European color coding, their romex-style cable is much closer to UF cable, their load centers use IEC components and DIN rail (much like an industrial control panel), they don't use wire nuts, they use "trunking" (similar to our wire mold) and they talk with an English accent. ;)
· Fond of three phase
I was always fascinated by the ring circuits. 2.5mm wire (13awg-ish) on a 32a OCPD, that's a lot different haha
Ring circuits are supposed to start and finish at the same point. So, in reality the conductors are in parallel, throughout the entire run. That would double the ampacity of the circuit, unless the circuit is compromised by miss-wiring.
Yep. I have worked with these my whole life so are used to this configuration and the numerous faults due to a broken ring (quite common)
A concern nowadays is over here, in kitchens people are wanting a switch panel for all the appliances (for isolation for our regs) that has labeled switches in one place . This means the ring could be very unbalanced as say one leg has a 5m run to the board and the other 30m round the kitchen outlets also. Our 'normal' cable for this is 2.5mm which generally can carry 20A max.
· Retired Account
I am an electrician in the uk, what is it you want to know exactly
I'm an electrician in America which is a rather isolated existence compared to the Euro electrical scene Martin.
Perhaps you blokes would be kind enough to take this opportunity to opine on your methods? For instance ring circuits>>
Why run a circuit this way would be my first Q.....?
1 - 20 of 50 Posts
