Not quite sure what I think about those...These breakers are 1200 amp. It's a square D gear. First lugs I ever saw like these.
Better to have it and not need it. Than to need it and not have it.
They make me wonder too. Guess we find out the end of this month, when we do the shut down and power swap.Not quite sure what I think about those...
No you back the top screw out a ways and then land the bottom lug first. The Allen shaft passes through the top lug screw.nrp3 said:So, you take out the top set screw, tighten up the lower one on the conductor. Then insert the upper conductor, install the upper set screw again and tighten?
Infrared, case closed.I would hate to have to retighten those connections . Or even check them .
why would you use those to change out a ballast?:laughing:Used them plenty of times with no issues yet
God damnitbutcher733 said:why would you use those to change out a ballast?:laughing:
