Does anyone know if a vehicle inspection pit where no work is performed would be a classified location? It is just for the visual inspection of the braking system. But of course the truck would be holding fuel above the pit. This is an open pit with no roof or building around it. I am just having a problem figuring out if im using emt with compression fittings, pvc, or rigid conduit on this job. I will call the local inspector in the am and find out for sure.
