I'm coming up to Canada to tear the U right off your keyboard.How do you guys run HDMI to a wall mount TV without damaging the vapour barrier?
Okay, I'll give you my address. It's the house with the Harleys parked in front and the windows painted black. Don't bother knocking, just walk in.I'm coming up to Canada to tear the U right off your keyboard.
Well then in that case the same way you would put an outlet in the wall.Gee thanks. I'm not fishing, this is rough-in.
You don't understand air infiltration, do you? On second thought maybe you do...Well then in that case the same way you would put an outlet in the wall.
This seems like a DIY post
