I think the building code guys jackboot you for running HDMI in the walls. I'm pretty sure you can connect these with Cat 5 but I'm not sure. I'm running this for TV.I would think that you would run a hdmi cord from there to its base. like this???
you may be right but I have never done this so I don't know. I saw this plate on line and another that says to use hdmi cable. Someone will knowI think the building code guys jackboot you for running HDMI in the walls. I'm pretty sure you can connect these with Cat 5 but I'm not sure. I'm running this for TV.
I'm not aware of any code that does not permit HDMI cable in a wall. It may be a Canadian code though:001_huh:I think the building code guys jackboot you for running HDMI in the walls. I'm pretty sure you can connect these with Cat 5 but I'm not sure. I'm running this for TV.
I don't know, I'm just talking through my butt. Maybe there's a flame spread issue, maybe not. I'm just doing a little commercial job where I need to run HDMI from a floor box to a TV. I always have Cat 5 or 6 in the truck and going to the supplier for an HDMI cable is always a pain in the a$$.I'm not aware of any code that does not permit HDMI cable in a wall. It may be a Canadian code though:001_huh:
Pete
http://youtu.be/Da5SMuqQJ_8I think the building code guys jackboot you for running HDMI in the walls. I'm pretty sure you can connect these with Cat 5 but I'm not sure. I'm running this for TV.
Yes but hdmi is not performing the function of wiring equipment. Heck telephone wire is run thru the walls. I assume the hdmi is a class 2 cable and should be finehttp://youtu.be/Da5SMuqQJ_8
This mike holt video I have found to be very helpful in regards to flexible cords and cord assemblies (which HDMI would fall into).
I'm seeing 19 conductors but maybe all of them are not used? It seems like it would be more of a PITA wiring cat5 up then getting the correct cable.I don't know, I'm just talking through my butt. Maybe there's a flame spread issue, maybe not. I'm just doing a little commercial job where I need to run HDMI from a floor box to a TV. I always have Cat 5 or 6 in the truck and going to the supplier for an HDMI cable is always a pain in the a$$.
Not all of it, just make sure what you buy has the rating.I have checked a few sites and the hdmi appears to be CL 2 so it should not be an issue
You cannot run any cable in the walls of a combustible building unless they are rated for it.Pete m. said:I'm not aware of any code that does not permit HDMI cable in a wall. It may be a Canadian code though:001_huh: Pete
Do I only run one Cat 5, Hack? Maybe I'll run two just in case. It's only twenty feet.How long is the run?
I would go to Monoprice.com and get a simple CL2 rated HDMI cable for 40' or less. I know others who have run it 50' or more, but I never went that far.
If you need to go further, use some type of balun device that runs the data over CAT5 cable, such as the coverplates posted in post #10.
If it's only 20', just get an HDMI cable. Plug it into cover plates like Dennis posted in post #2... or just have the end of the HDMI cable come out of the wall thru a "scoop" type cover plate.Do I only run one Cat 5, Hack? Maybe I'll run two just in case. It's only twenty feet.
