1 - 12 of 12 Posts
How many kw to heat an un-insulated 20' shipping container in a Canadian winter
Discuss
Why bother?
15kw running 24/7
Where in Canada? Big difference from Manitoba and Vancouver Island
How warm. Just to keep above freezing, or warm enough to live in?
Estwing magic
Go here:
www.ouellet.com/heat-capacity-calc.aspx
Geography doesn't really mean anything. What you're dealing with is the difference between the lowest outdoor temperature and your desired indoor temperature. As a wild a$$ed guess, 5 to 7.5KW will probably make the temp inside your sea can bearable but you need to seal off the door somehow.
I would put in two of the little 5KW garage heaters. May be a lttle over kill but at $265 a piece who cares.
1 - 12 of 12 Posts
