1 - 18 of 18 Posts
I have installed heat trace in roof drain lines before and have a customer which we wired their building request heat trace be installed the entire drain line because it’s freezing up all winter. The line is 4” PVC and is 150’ long (mostly underground) until it hits the catch basin-man hole. In looking on the web nothing really states that this can be installed like this, anybody else come across this?
Modérateur
Run the heat trace outside of the PVC pipe.,
second thing .,
How deep this pvc drain pipe is in and pitched correct ?
Discussion Starter #7
second thing .,
Pipe is 5’ under a lumber yard asphalt slab, is 4” and draining properly when it’s not frozen. Raychem rep says to go ahead and use GM-2X line? Guess I will
If the drain is 5' under ground, what is your frost line?
Sent from my XT1254 using Tapatalk
Discussion Starter #10
Normally 3-4’ here under regular conditions, but in a high traffic area it can get to 8’!
Petulant Amateur
Put self reg inside the pipe but go to a manufacturer's website to check out maximum run length and circuit breaker size. 240V cable most likely.
Chief Flunky
Sewage plants call it I&I. Rain can easily overload and overflow a wastewater plant. Older systems in the US ran them together. Newer systems separate them.
Sent from my SM-T350 using Tapatalk
Test
It took a while to digest why we call the **** sewer a "sanitary" sewer. It creates sanitary conditions in the buildings which they are connected to.
And storm sewer doesn't sound as clean as it is, because of the word sewer. But that's what we call it in the code books.
Our city has a marina. They call it the City Yacht Basin. To me a basin is something my mother handed me when I was sick so I could vomit in it. I'd much rather see the city marina called the "City Marina". But I'm not on city council.
1 - 18 of 18 Posts
