1 - 8 of 8 Posts
I have been asked this question among a few others:
Using a line diagram draw out how you would wire in a starter with overloads that have a single position switch, high vibration, low oil and a remote on /off switch.
Please help!
· animal lover /rat bastard
sounds like a nice homework question. what happened - you were texting in class and not paying attention ? you probably won't get any help unless you at least take a stab at it and post that first.
· Coffee drinking member
NDBakkenSparky said:
I have been asked this question among a few others: Using a line diagram draw out how you would wire in a starter with overloads that have a single position switch, high vibration, low oil and a remote on /off switch. Please help!
Draw each required item first in the start circuit then connect the parts.
Toss a picture up here and see how it goes.
That or someone got a job low balling it and has no idea how a control circuit works... Just making a guess based on the OP's name, as it is a relatively easy controls question....
1 - 8 of 8 Posts
