1 - 10 of 10 Posts
I am currently a student going into the industrial electrical field. I am working on a formula sheet that will help me, and a few other students. Could I have someone go over the following and let me know if there is anything else I am missing or anything that might be wrong? Here is a link to my word doc in skydrive.
http://sdrv.ms/QUZ7SY
RIP 1959-2015
Welcome to the forum..:thumbup:
Your link is not working.
I own stock in FotoMat!
Electrical Formulas Based on 60 Hz
Capacitive Reactance (XC) in Ohms = 1/(2p f C)
Effective (RMS) AC Amps = Peak Amps x 0.707
Effective (RMS) AC Volts = Peak Volts x 0.707
Efficiency (percent) = Output/Input x 100
Efficiency = Output/Input
Horsepower = Output Watts/746
Inductive Reactance (XL) in Ohms = 2p f L
Peak AC Volts = Effective (RMS) AC Volts x Peak Amps = Effective (RMS) Amps x
Power Factor (PF) = Watts/VA
VA (apparent power) = Volts x Ampere or Watts/Power Factor
VA 1-Phase = Volts x Amps
VA 3-Phase = Volts x Amps x
Watts (real power) Single-Phase = Volts x Amps x Power Factor
Watts (real power) Three-Phase = Volts x Amps x Power Factor x
Parallel Circuits
Total resistance is always less than the smallest resistor
RT = 1/(1/R1 + 1/R2 + 1/R3 +...)
Total current is equal to the sum of the currents of all parallel resistors
Total power is equal to the sum of power of all parallel resistors
Voltage is the same across each of the parallel resistors
Series Circuits
Total resistance is equal to the sum of all the resistors
Current in the circuit remains the same through all the resistors
Voltage source is equal to the sum of voltage drops of all resistors
Power of the circuit is equal to the sum of the power of all resistors
Transformer Amps
Secondary Amps 1-Phase = VA/Volts
Secondary Amps 3-Phase = VA/Volts x
Secondary Available Fault 1-Phase = VA/(Volts x %impedance)
Secondary Available Fault 3-Phase = VA/(Volts x x %Impedance)
Delta 4-Wire: Line Amps = Phase (one winding) Amps x
Delta 4-Wire: Line Volts = Phase (one Winding) Volts
Delta 4-Wire: High-Leg Voltage (L-to-G) = Phase (one winding) Volts x 0.5 x
Wye: Line Volts = Phase (one winding) Volts x
Wye: Line Amps = Phase (one winding) Amps
WYE
EP (primary) = EL / 1.732
IP (primary) = IP (secondary) / Ratio
EL (primary) =
IL (primary) = IP (primary)
Ratio = EP (primary) / EP (secondary)
WYE
EP (secondary) =
IP (secondary) =
EL (secondary) =
IL (secondary) =
WYE
EP (load) = EL (load) / 1.732
IP (load) = EP (load) / (R or Z)
EL (load) = EP (load) * 1.732
IL (load) = IP (load)
DELTA
EP (primary) = EL (primary)
EL (primary) = EP (primary)
IL (primary) = IP (primary * 1.732
DELTA
EP (secondary) = EL (secondary)
IP (secondary) = IL (secondary) / 1.732
EL (secondary) = EP (secondary)
IL (secondary) = IP (secondary) * 1.732 = IL (load)
DELTA
IP (load) =
IL (load) =
Volts = E = V
Current = I = Amps
Resistance = R =
Capacitors = C = farared =
Inductance = XL = Henrys = H
Frequency = f
Phase = P
Line = L
I am reading my book and i dont see where it is telling me how to get the Ep EL IP and IL for the secondary wye. The parts that im really most interesting in making sure are correct are the following:
WYE
EL (primary) =
WYE
EP (secondary) =
IP (secondary) =
EL (secondary) =
IL (secondary) =
WYE
DELTA
DELTA
DELTA
IP (load) =
IL (load) =
RIP 1959-2015
WYE
EL (primary) =
WYE
EP (secondary) =
IP (secondary) =
EL (secondary) =
IL (secondary) =
WYE
DELTA
DELTA
DELTA
IP (load) =
IL (load) =
Take a look at this link...:)
http://books.google.com/books?id=vR...p EL IP and IL for the secondary wye.&f=false
1 - 10 of 10 Posts
