Some of you have said you only use 12 wire.I would like to just say 14 is superior to 12 wire in certain situations. I will only discuss residental.
Consider:
1. general purpose receptacles, 14 wire puts less pressure both on the box edges and the terminations.
2. Dedicated refrigerator, Come on refrigerators are like 6 amps tops now.
3. Lighting, most lighting circuits will never see more than 12 amps or 20 60 watt fixtures. Once again termination pressure yada yada yada.
4.Gas Furnace, once again only 4 or 5 amps.
Most electrical problems are caused by poor terminations not overloaded wire. I think we could all agree 14 wire fits better on screw terminations and puts less pressure on the device.
I only use larger wire when I must such as bathrooms kitchen counter tops and appliances greater than 15 amps.
What reasons would you, hypothetical straw man, use to justify not ever using it?
Consider:
