Thought I'd take a few pix to show you how I drive ground rods.
I got a Hilti 905AVR with two ground rod drivers.
This is a beefy machine, and the weight alone will drive the rod.
In addition to the 'standard' ground rod driver,
I also got a special attachment that prevents me from having to climp a ladder to start driving.
The ground rod slides in through the body, and the handle is tightened down on the rod. You can do this anywhere along the rod you want. Stand it up and start driving. When this attachment gets near the ground, loosen it, move everything up, tighten it down again, and continue driving.
When you get near the end, you can 'finish it off' with the 'standard' driver.
Even in the most difficult situations, I've never taken more then 2 minutes to drive a rod. I'm sure I've broken a few large rocks below grade with the power this little baby has.
