1 - 3 of 3 Posts
I understand it will differ from area to area but in general what is the process the local's use to bring on new apprentices? Obviously the first step is the application, then what? And after hired do they normally wait to start you working when classes start or is it more of a case whenever they need somebody. Thanks in advance!
Contractor driven on the short end. They need bodies, the hall better move a warm one in. What that warm body does early on is significant to building a good career.
Normally work before school. if your a slacker at the grunt end...see ya, we need producers!
When you see this from that angle it gets pretty easy.
Just go to work, do a good job, let them give you direction (nobody likes a foreman apprentice!) make friends and do good.
Go take some math classes at your local community college(algebra, trig, maybe some single variet calc if your brave. You might test out of some of the Apprentice school too. The contractor I am working for was looking for someone with math skills. They were having trouble with their apprentices and math after they started school. You will have a leg up and get the job. I interviewed against 15 other candidates and got the job because I had a better resume and highlighted that I was enrolled in college and stated which math courses I had taken in my interview.
I do not start ABC classes until September, I have been working for them for 2 months. Like rockyd said they want to see you will work, be on time, be productive, and especially do the grunt work. Even as a journeymen you will be doing grunt work, so if you can't do it as an apprentice, see you later. If you can then they will spend the money to send you to classes.
1 - 3 of 3 Posts
