A family friend just closed on a house that was an estate sale. Everything is pretty much original except for a new range feed, which was installed professionally and the dryer feed which comes out of the panel goes halfway across the garage stapled to the sheetrock to a flying splice taped the size of a small softball. Also, there's no ground at the water meter. No mention in report.
The last one was a log cabin with a master bedroom addition without a footing under the main support column. Looking at it from the street you could see that it sunk and tilted a little. There was also a meter/main with SEU run under the house to the panel in the closet behind the boiler. No mention in report.
At least get the big stuff
