Residential and commercial services, troubleshooting , lighting and design
I have a problem with a homeowner who doesnt want the old service mast , which was installed through the roof, to be cut off under the roof and the roof patched. He just wants it capped but the building inspector wants it cut and the meter base which is flush with the brick to be sealed. The homeowner now has a lateral service. I pulled the permit. I told the homeowner that this is what is needed as required by code but he still will not pay to have it done.
I have also replaced the load center from an old GE to a new Eaton In the basement. The old GE is next to the new and is rigid metal piped to the outside meter base.
The basement is an electrical nightmare of old extension cords and junction boxes from decades of DIY. I stripped most of it away and now the homeowner wants me to reconnect in the new load center the old branch circuit wires. I had divided the work into two phases; the new service, then rebuild and demolition. The existing circuits are looping through several rooms from the basement, and the attic has junctuon boxes from Hell, and lol snake skins are looped through the insulation. I told him that it is a requirement to have a light and receptacle to service the load center and he referred to my portable light. This man is not in any way strapped to afford quality but it seems that he cant keep a contractor. I know that I will not get a final inspection until that old service is gone.
My problem is this: Isn’t there a code section that states all of the old service entrance and panel be removed to pass inspection? They never lost power to the house, and I am building the new panel schedule with both panels live, then I will remove the jumper and breaker feeding the old one when I have all of the old circuits removed and fed from the new panel.
Did I trap myself? It is common in this area for mechanical and plumbing contractors to come in and do work without a permit.
