1 - 18 of 18 Posts
I looked at a job today that had a service just for the water meter..this was a residential home with a 100 amp main and a hot water meter with a a fused disconnect..the disconnect is damaged and I have to replace it.. What is the best way to go about this? I was thinking just thinking to replace it with a service rated enclosure and 30 amp breaker and call it a day..the meter looks like one of those smart off/ on peak meters..
felonious smile.
Old New Jersey stuff
Why would you need to heat hot water?:001_huh:
Sparks fly from my finger
Around here that used to be a thing when people had electric heat. The recs billed it at different rates. I think some if them only had a water heater also since that was considered electric heat.
Not sure where you're located but PECO used to offer a discounted rate on your water heater. They no longer do this. That 2nd meter can probably go away and you can just land your wire in the main panel.
I have never seen a water heater that was metered as a separate service. Usually there is a breaker that feeds the meter and the the meter feeds a diso at the water heater,
The power company can control the wh during high demand and the customers gets a small rebate every month
Reactions: pete87
Jesus Scott
Very common around here. I don't know of any that are still in use as far as separate billing goes. I always do the same... Remove the extra meter and land circuit in panel.
Can't Remember
I have one meter for the electric water heater and one for the rest of the house. Not sure how much savings there is after you pay for the extra meter.
Discussion Starter #16
They only have 100 amp main..everything is electric in the house..dryer , range , ac, etc... I don't know if it's going to trip the main...
1 - 18 of 18 Posts
