1 - 12 of 12 Posts
I'm going to give a price to a general contractor for a complete house re wire job from knob and tube. There are no prints for it. Should I make my own prints and submit them with the bid to show exactly what is included in my price? Then price according to the opening?
RIP 1959-2015
Mmmm,, no.
You should write out what is included and what is not.
Take each task and put a time on it to get the number of man hours it will take, then add up all the stock, mark it up.
Add it all up, and give a grand total price with payment terms.
Something like this?
200 amp overhead service with 24 space panel
6 20 amp ckts
6 15 amp ckts
2 30 amp ckts
20 receptacles
6 single pole switches
4 120 volt smoke detectors
8 6" led recessed lights
2 dimmers
Basically show the quantity and device/task with 1 total price?
You're going to bid a knob and tube rewire??? Do you have an x-ray machine to see if theirs fire blocks in the stud cavities? I might give someone an estimate but I don't think I'd want to take the chance bidding on something like this. Not unless they're going to gut the house.
Sorry, forgot to mention it is a gut job. I guess I will go by code for receptacle and smoke detector locations and then talk with the home owner/general about lighting and switch locations. The kitchen will be done at a later time, waiting on cabinets, so I will have to find a way to feed it from the new panel temporarily.
Freelance Member
I would include everything that Im including in my bid. Exactly. Every recep, switch, box, feet of wire, etc.
If you dont want to get that detailed I would write each outlet as an assembly. Which might include 15' of wire, a box, a receptacle. In the bid write somewhere what assembly means, like a general description of it.
I would include a small paragraph stating what I was not suppling or doing. Lightbulbs and lighting fixtures to be provided by customer, etc.
I would do a take off of my own mental prints and price the job accordingly. After you think you have your price mark it up 25%. Gives you some room.
Dont forget demo if youre doing it.
6 20 amp ckts
6 15 amp ckts
2 30 amp ckts
20 receptacles
2 dimmers
This is what I would do.
Do a walk-thru and make notes of every room. Then do your take-off from those notes, but only give them the quantities. I would NOT do an as built plan for them that they can bring to anyone else so they can easily bid from it.
HA! I would have never thought about another EC using it to bid against you, pretty smart. I'm just to lazy to go to the trouble of doing something like making a set of as-built plans, so I would've never run into that. :laughing:
1 - 12 of 12 Posts
