They don't, that's why they have a bad name!:jester:I understand that arcs create a different waveform than the typical sine wave, but how does this device make a distinction between an arc in a damaged cord and other "acceptable" arcs?
To be fair to MH Forums, any thread gets closed if there is no activity in x number of days.So the afci cabal found someone from Taiwan to write a paper, and Holt's forum closes yet another afci thread
I don't know what you said, but if you put root beer in a square cup it becomes beer.humm i would like to see an afci breaker connected after an inverter with square wave output :laughing:
+There are no acceptable arcs.I understand that arcs create a different waveform than the typical sine wave, but how does this device make a distinction between an arc in a damaged cord and other "acceptable" arcs?
What he prob meant is that some devices in normal operation will feedback a waveform that looks like that of an arc, but is uniquely different.+There are no acceptable arcs.
Is there such a thing as an acceptable arc ?I understand that arcs create a different waveform than the typical sine wave, but how does this device make a distinction between an arc in a damaged cord and other "acceptable" arcs?
good point:thumbsup:Is there such a thing as an acceptable arc ?
I would have thought that any arc has the potential to cause damage,
So they should be avoided.
The manufacturers of afci technology seem to think they can ignore both Paschens law , as well as the reality that a glowing connection occurs before the degrade into an arc .
so the pursuant questions would be....
>>> which is of the most & enduring incendiary caliber ? That this forum alone is lousy with pictorals of overheated electrical equipment should be evident (keeping in mind our lower V & higher magnitude)
>>>how are arcs sustainable below the parameters of Paschen's 347 volts on our 120V system viably monitored by any technology:whistling2:
It's been questioned....Does an arc fault trip on any arc ?
Or just some ?
http://www.mikeholt.com/mojonewsarc...I_-_Why_I_Have_a_Problem_With_It~20020801.htm
Consider yourself lucky....I have not come across an arc fault breaker here in Australia.
Not sure if we even use them here.
Maybe it's a USA thing.
USA, and possibly France in the near future
In the wiring in the walls? No. From the brushes of a motor? Yes. As feedback from electronic devices? Yes. As the arc when switch contacts make or break? Yes.Is there such a thing as an acceptable arc ?
