Put as many plugs out there as you want. Absolutely no restrictions on that. There are limits on receptacles, however.
I googled "plugs" it was quite disturbing. I would hate to think what Bing would pull up.Put as many plugs out there as you want. Absolutely no restrictions on that. There are limits on receptacles, however.
should've said receptaclesI googled "plugs" it was quite disturbing. I would hate to think what Bing would pull up.
I guess I have to run new circuit to be up to code... and it's -30CA 14/2 circuit used for car plugs?
1 duplex serving two stalls - maybe, depending on distance.
4 parking spots but never more than 3 buses parkedHow many parking spots are there? You need one circuit per spot, only one duplex receptacle per circuit. CEC 8-400
It's common to use one split plug for two stalls.
how much?
As per 8-400, you would need four 15 amp circuits.4 parking spots but never more than 3 buses parked
About $ 150 -$ 175 per.how much?
NoAre these receptacles metered such as in dropping a $1.00 in the machine for 3 hours of electricity.
Might be worth designing a parking meter like head that accepts coins and CCs in exchange for powerIs there such a thing as public receptacles for engine heaters? How do they bill for electricity.
Yes and no. You can't pull into Walmart and plug your car in.Is there such a thing as public receptacles for engine heaters? How do they bill for electricity.
