1 - 20 of 84 Posts
Slave to the grind
Hmmm....let's see here.
Since the polarity was reversed, and he didn't run the unused screws down and, there probably isn't an EGC in that old metal box....who wants to bet that the silver screw, with the hot wire, is touching that metal box? Sure looked like it could have been to me.
The dude probably just created a bigger hazard than he already had.:001_huh:
Scotchkote Installer
Someone should make a video about receptacle screw identification..
The white wire goes to the silver screw... not the brass one..
The hot goes to the brass one...but this moron has much bigger problems than changing receptacles wrong...
I bet his house is loaded with Carlon blue electrical boxes that he is so proud of installing all by himself.. :eek::eek::no:
Electrical Simpleton
Tell the truth.... which one of you business owners has been trying to find contact information to give him a job offer?
Pete
Coffee drinking member
B4T said:
Someone should make a video about receptacle screw identification.. The white wire goes to the silver screw... not the brass one.. The hot goes to the brass one...but this moron has much bigger problems than changing receptacles wrong... I bet his house is loaded with Carlon blue electrical boxes that he is so proud of installing all by himself.. :eek::eek::no:
Maybe the dude is color blind?
Holy sheet that is the worst video I've ever seen for hackery.. it's gotta be a joke!
Reversed polarty, no grounding/bonding, it's tamper-resistant but he says you should still put in child safety plugs.
w t f
and yes, what is with that amish haircut?
Discussion Starter · #12 ·
:jester:.. and don't forget the old "BX" Type R conductors that are dried up like a pretzel, and the soldered taped (with friction tape) splices to the pigtails, and the less than the 6 inch tail.
He didn't remove his ring at the very beginning as well. The tools were impressive too. I tracked him down and called him, no reply yet and his YT page does not allow comments!
Certified Organic A-Hole
My friend's dad called me over once because he was replacing his well's pressure tank and didn't remember how to wire the pressure switch back up.
When I got there, there was an old guy talking to him saying I think the black is your hot and the white is the negative. I chalked it up to either a very old electrician or a guy that thought he knew what he was doing.
It was a 240v single phase pump, I had it fixed in a matter of 15 minutes but had to wait for them to get new fuses as they blew the new ones they bought (created a dead short when the wired the pressure switch back up.)
:laughing: I've got one of those screwdrivers he was using. I'm going find it tomorrow and get rid of it.
1 - 20 of 84 Posts
