If you want the oven to have priority it's probably possible.Power is limited to an existing apartment. To be granted all the proposed loads by the building management, we must install a switch or relay of some kind that will prevent the use of an air conditioning unit while the oven is in use. The load is 208v 30 amp.
Any idea what I can install to make this automatic.
