1 - 20 of 34 Posts
The way you are placing the items means you'll need 3-wire between the light and switch.
Do you have to draw a diagram for it? If so why not do that and post it. We'll tell you how you did.
Electric Al
I'd say your NM-90 needs to be 3wire.... ~CS~
Exactly !
From the box the light outlet is on , to the switch , it will have to be a three wire cable !
Try it !
You should be able to figure it out .
If we do it for you , how will you learn ?
1 - 20 of 34 Posts
