How would you hook up a straight 240 dryer?
  • Use 6-30r and move white wire to ground bar in sub.
    Votes: 4 66.7%
  • Reuse 10-30r outlet and leave as is.
    Votes: 2 33.3%
1 - 7 of 7 Posts
· Bilge Rat
motors and controls.........
It it is fed from the main panel, I'd leave the 10-30. The white is already landed on the neutral/ground bus.
If it is fed from a sub-panel, I'd change it to the 6-30 and re-land the white on the ground bus. And tape it green.
That's probably what I will do. Normally Id just pull a 10/3 with ground but the laundry is on the second floor with the panel on the other side in the attached garage. A new home run would be impossible.
1 - 7 of 7 Posts
