1 - 2 of 2 Posts
Hey guys,
Taking a shot in the dark here hoping someone has worked on these before. We have a hyd mech v18 automatic vertical bandsaw
When we try to adjust the blade speed the unit just locks up, the hydraulics and all other functions work but the blade won't move.
Turn the dial back to where it was and it runs at it's current speed.
It's possible it's just a pulley, clutch, or spring that is shot, but before I pull this unit out of production to find out it's something more serious i thought I'd ask you opinion
Thoughts
Thanks
Continuous variable pulleys? Maybe one of them is locked up and the belt is getting too tight. If you try the other direction does the belt get too loose?
1 - 2 of 2 Posts
