Are they a good starting point for learning what is useful to know in the field? I can over half of them off the top of my head right now.
1. What is a PLC, and what does it do?
2. Name three types of PLC's.
3. What is the most common method used in PLC programming.
4. Name to other types of PLC programming.
5. Name three types of input cards.
6. Name three types of output cards.
7. Can a 4-20 ma analog input card be used on a 0-10 volt signal?
8. Can a 0-10 volt analog input card be used on a 4-20 ma signal.
9. How many outputs are needed to control a 1/10th hp 480 volt three phase motor?
10. Draw a simple AND input ladder.
11. Draw a simple OR input ladder.
12. Draw a simple NOR input ladder.
13. Draw a circuit with a NO input and NC input to latch a relay coil.
14. Draw a simple circuit, using a 480vac signal and a 24vdc input card, and a resident smoke timer.
15. Name 5 different uses for a PLC.
16. Draw a simple stoplight program.
17. Draw a one shot or a flip-flop ladder diagram.
18. How do you lengthen scan time?
19. Why would you use online programming or editing?
20. Can two output coils have the same address?
21. Write down a basic motor control circuit.
22. Differentiate between source and sink inputs on a PLC.
23. Discuss the use of an E-stop circuit in a motor application.
I'm just trying to gauge what I should be learning to do PLC work professionally once I have my EET degree.
