I am not sure. It has a part number as a breaker. It may be used as a switch tho. Note the threaded holes on the face. It mounts to an instrument panel.Big John said:Is that a breaker or just a fused molded-case switch?
The bottom and the label seem to indicate it's a 3 amp device, whether that's trip current or switch rating I dunno...
Q for me John? It's a breaker.Is that a breaker or just a fused molded-case switch?
No I do not do solar. It is out of a locomotive.coil power said:I has a breaker-image-3664668093.jpg
I see a 3 amp rated DC control switch, you do any solar? The only solar job I worked on had switches and breakers that looked a lot like that.
Never seen one of those in person. It was on here that I learned they were even still manufactured.It's a hydraulic magnetic circuit breaker....
Is the hydraulic portion under pressure?Big John said:Never seen one of those in person. It was on here that I learned they were even still manufactured.
Nola, open that thing up so we can see how it works! :laughing:
