I had a breaker tripping. Opened everything on that circuit, and everything looked and tested good. Disconnected neutral and the breaker held. Touched it to neutral bar and it still held. Reconnected the neutral all was fine. Turned everything on and took an amp reading. That too was good. Assumed the breaker had crapped out, and replaced it. Just got called back to the house, same circuit. Tripped and wouldn't reset until I disconnected and reconnected the neutral.
I had asked the home owner what they were doing when the circuit tripped. Both times they said just watching tv. I cannot figure out or understand the cause/solution to this. Any ideas or input would be greatly appreciated.
