1 - 2 of 2 Posts
Can anyone explain why they gave an exception to using a 'in use' weatherproof receptacle cover if you using a routine high-pressure spray washing? 2011 NEC 406(B)(1).
It appears one would need it (in use cover) more when spray washing is going on.
This issue came up and there was a debate on whether or not an 'in use' cover is required or not.
General Superintendent
because an in use cover is useless for high pressure spray down, everything inside is gonna get soaked.
1 - 2 of 2 Posts
