1 - 17 of 17 Posts
What kind/brands are you guys using (everyone is using them now right;)). Was hoping to get a decent setup both for work and occasional wrenching at home. Don't need anything insulated, we never work hot:whistling2:
wiha
How much are you going to use it? If only occasionally, just get a Craftsmen or something similar. If you're using it for torqueing lugs, either get an in/lbs. or get a ft/lbs. and do the math.
Gold Member
Just bought the Wera 3-set, does(iirc) 3 to 55 "lbs across the three drivers. Spendy, but really nice.
antisocial group ******
I just use a regular driver and twist until the plastic cracks the first time.
Proud Navy Veteran
For my inch-lb driver I use a Klien but all of my other torque drivers are Snap on.
Coffee drinking member
Does anyone remember the formula needed when an extension is used on a torque wrench?
It's been years since I've used it..
Ontariojer said:
If you mean socket extension-there is no formula, since there is no difference. If you mean handle extension-hit the gym;)
No not the handle... There is one, we learned it for building ordnance and repairing my 5" gun mount. We even had resistors with a zero tolerance.
QUOTE="maddhatter"] [ Torque x Length of Torque Wrench ] / [ Extension Length + Length of Torque Wrench ][/QUOTE]
Thanks
Gold Member
Thanks[/QUOTE]
Ok, so I think this is the formula for multiplying your torque for applications outside your drivers range using extensions on the socket, but in-line with the handle,yes?
I was talking about an extension in-line with the socket. No formula.
THIS is why a picture is worth 1k words!:laughing:
1 - 17 of 17 Posts
