1 - 11 of 11 Posts
Thanks for the comments.
Everything is wood.
I have a DWG file of everything so adjusting lux levels shouldnt be a problem.
There are two problems:
The budget is tight and we need to fit into 4kW.
About the disco - Its usually rented out for a specific event.
Im trying to get aprox even 300lux, but the 4kW are killing me.
· NO high voltage here
I used to frequent skate parks, and a lot of them used the larger halide style lighting, mixed with fluorescent lights.
I wish i knew more about lights, but I am a low voltage guy.
as for vandals, its rare. Skate parks are zero tolerance for this ****, and kids dont wanna loose they spots.
The only place it comes to be an issue, is if the ramps are 10-12 feet tall, and then the boards can fly off the ramps and hit them.
Also, the ramps reflect a decent amount of light.
Everything is wood.
I assume this is indoor? I have done two outdoor parks, both designed to 30-35 f/c's 300lux-350lux. Only way to do it was with 1000w metal halide. What is the ceiling height? How large is this space - length x width?
1 - 11 of 11 Posts
