hmmm, i always tend to think the other way 'round on lights Ablyss.....:001_huh:~CS~Lamp loads fall into several categories: tungsten, fluorescent, electronic, HIDs, and more, but tungsten in general has an inrush like motors do. Usually 10-15x the current inrush.
Me too, but it can be counter-intuitive. A light can be anything from a single bulb, or an entire floor with many bulbs. In the latter the inrush is calculating the sum of all lights.hmmm, i always tend to think the other way 'round on lights Ablyss.....:001_huh:~CS~
Just a little confused by this statement. Other than incandescent lighting, what resistive heating loads have a high inrush?Big John said:While a cold resistive heating load will have a high inrush, once the temperature stabilizes it will have a relatively low interrupting current when the contactor attempts to open the load.
I would think any load that has a very low cold resistance and then tapers off to a resistance in mid-range once it's up to normal temp. This resistance can only be calculated, not measured directly with a meter.Just a little confused by this statement. Other than incandescent lighting, what resistive heating loads have a high inrush?
Like I asked! other than light bulbs, I can't think of any other resistive heating loads that fall into this category. I'm not saying that there is not, just it can't think of any.Semi-Ret Electrician said:I would think any load that has a very low cold resistance and then tapers off to a resistance in mid-range once it's up to normal temp. This resistance can only be calculated, not measured directly with a meter. Similar to a motor starting to turn and one at normal RPM and developing counter-emf.
Most of them actually. It's called having a Positive Temperature Coefficient of Resistivity, meaning that as the temperature rises, the resistance rises as well. So when cold (off for a certain time), the resistance is low and current is high for a fraction of a second until the element heats up. NiChrome, the most common heating element material, has a relatively high PTC of Resistance, about 60x that of silver or copper. Tungsten is a lot lower than NiChrome, but still 4-5x that of silver or copper. So quartz and quartz halogen lamps, because the element inside is still tungsten, is high as well.Just a little confused by this statement. Other than incandescent lighting, what resistive heating loads have a high inrush?
Are all these heating loads for lighting? I guess I wasn't thinking about lighting as being a heating load.JRaef said:Most of them actually. It's called having a Positive Temperature Coefficient of Resistivity, meaning that as the temperature rises, the resistance rises as well. So when cold (off for a certain time), the resistance is low and current is high for a fraction of a second until the element heats up. NiChrome, the most common heating element material, has a relatively high PTC of Resistance, about 60x that of silver or copper. Tungsten is a lot lower than NiChrome, but still 4-5x that of silver or copper. So quartz and quartz halogen lamps, because the element inside is still tungsten, is high as well.
