:laughing:ok so in depth my question is can you use a 240VAC infinite switch like the ones on the stove on 110VAC provided that the load of the 110 circuit does not exceed the original (1500W in my case) application???
What would be the adverse effects?
Would it still trigger the bimetal stripe?
Would there be a delay in the triggering of the cut off making the unit stay hotter for longer?
please if you could spare me the obvious, you should never do this / safty label stuff, i have been in this dangerous electrical stiff for 14 years, but i have no experiance with infinite switches, and thusly have registered for the first forum on google! also the information i have researched on infinite switches is sort of limited as if no one knew how they worked o
Try this it might help you...http://electronics.stackexchange.com/questions/21420/operation-of-infinite-switch
I really don't know if it will make difference,,,,,Welcome to ET......:thumbup:
