1 - 9 of 9 Posts
I am typically all residential, but this shouldn't be a problem. The business owner said the salesperson told him it would require a 60 amp breaker. I'm wiring an Ingersoll Rand TS4N5 air Compressor. The plate says 230V and 21.5 FLA. Why would I need a 60 amp breaker?
It's going to be placed within 25' of the breaker box, so I was going to put a double pole 30 and use #10. Even if I did 1 1/2% it would be a 40 amp breaker. How should I wire this thing? Thanks so much! -John
electrical contractor
I have that compressor in my shop. I ran 10's on a 40. It kept tripping out once it had pressure in it. I ended up running 6 on a 60 amp breaker and never looked back. P.S. It is a great compressor.
If the tag says minimum circuit ampacity ____. Maximum CB or fuse size, then you use that. If not then I you have to use NEC 430.248 and add 25% regardless of what the tag says. Is the building 208 volts or 240 volts.
FYI : A NEMA motor rated hp is a measure of work while an IEC motor hp is a measure of how much energy it uses. That is why a NEMA 5 hp motor is bigger and draws more amperes than a IEC motor.
Depends if it has an unloader or not. If it don't, it'll start under full head pressure, and the 60a. would be my choice.
Air compressors notoriously start under a very heavy load. This is normal, and also why they don't repeatedly cycle. You can use a smaller breaker and swap it out if you get nuisance trips, but it sounds like your sales rep has seen this before and knows these units take a good 300% to start.
1 - 9 of 9 Posts
