I have a new customer who we "refurbed" a surface grinder for. We added a coolant tank to the machine and upon installation of the switch found that the "ground" for the machine had no grounding properties... Traced it back to the transformer and found that the ground wire to the machine was just connected to a disconnect box which was supposed to be ground through conduit but was not.... Well in my report I noted the issues and spoke with the owner of the company...
He wants me to come in and do a FULL inspection on the wiring in the entire building. So I will be testing all legs of power, amperage at boxes, verify proper wire, verify grounds at each machine, verify proper 110v wiring and ground, pull down any unused conduit and/or boxes....
What I have been looking for is a carbon copy checklist of sorts I can take along with me and make notes of all machines and outlets... I have our normal service report I will use also but I want something "electrical inspection" based that will show what was checked at each point and the results of the test... This is a little bit larger project than I am used to.
I am sure that there is more in depth tests that should/could be run but for now he just wants a basic safety inspection done because as we all know that a 220v machine that isn't properly grounded is dangerous for the components and operator....
My question is does anyone have a source for something like this? I have found many PDF's but nothing that I can order carbon copy booklets or sheets of.
Thanks for any constructive advice or criticism
