If there is a smoke alarm on the circuit, that would violate 32-110.
32-110 Installation of smoke alarms and carbon monoxide alarms in dwelling units
The following requirements apply to the installation of permanently connected smoke alarms and carbon
monoxide alarms indwelling units:
(a) smoke alarms and carbon monoxide alarms shall be supplied from a lighting circuit, or from a circuit that
supplies a mix of lighting and receptacles, and in any case shall not be installed
(i) where prohibited by Rules 26-720 to 26-724; and
(ii) where the circuit is protected by a GFCI or AFCI;
Other than that, I see no other rules, unless the circuit is afci protected, then you would have to install a dead front. Has anyone heard of issues with afci and gfci on the same circuit?
none....install gfci receptacles on afci circuits all the timeIf there is a smoke alarm on the circuit, that would violate 32-110.
Ive had to do it a few times when I wire sunrooms. There seems to be a real misconception with some inspectors wether or not its a room or a screened in porch.none....install gfci receptacles on afci circuits all the time
been doing it for years
around here most make you afci if it has windows, heated or notIve had to do it a few times when I wire sunrooms. There seems to be a real misconception with some inspectors wether or not its a room or a screened in porch.
I always thought the defining line was wether it was heated (living space) or not (enclosed porch). Its not that cut and dry in some areas though.
depending on the job, I may pull an outside receptacle off an afci circuit and toss a gfci receptacle in instead of running a new circuitIve had to do it a few times when I wire sunrooms. There seems to be a real misconception with some inspectors wether or not its a room or a screened in porch.
Interesting. What if it was a garage with a window in it?around here most make you afci if it has windows, heated or not
if it has a roll up door, its a garageInteresting. What if it was a garage with a window in it?
No, I was asking if a garage had a window in it, if your inspectors would make you put an arc fault breaker on it.if it has a roll up door, its a garage
now that's just being sillyNo, I was asking if a garage had a window in it, if your inspectors would make you put an arc fault breaker on it.
Not a garage roll up door. I must have not made that question clear enough.
OK, OK. :laughing:now that's just being silly
you were talking about sunrooms or porches
Except most fixtures say that when installed above a shower/tub they need to be gfci protected. Bastards. OP, what about a dead front gfi? That's gotta be cheaper than a gfi breaker, and will ease your mind for nuisance tripping.Semi-Ret Electrician said:In the US a shower switch (not actually located in the shower) or even a recessed shower light doesn't have to be on a GFCI but I do it all the time.
Has he been smoking crack with your mayor?So a home owner got a list of things to fix. One of them is a switch is too close to a shower. So I have two quick options. One is get a GFI switch (they exist but hard to get), and the other is put a GFI breaker on whatever CCT feeds that switch. My only concern is what there maybe a whole bunch of other things on that CCT, I haven't investigated yet. Can anyone think of any reason why an inspector wouldn't like a GFI breaker protecting more then just the washroom?
A sunroom would require AFCI protection. A porch, GFCI protection. The difference between the two can be determined by whether it was a habitable room or not.Interesting. What if it was a garage with a window in it?
yep, they added the word devices--I believe the 2014 will require afci if the switch controlling the lighting is in a room that requires afci protection
(A) Dwelling Units. All 120-volt, single-phase, 15- and
20-ampere branch circuits supplying outlets or devices installed
in dwelling unit kitchens, family rooms, dining
rooms, living rooms, parlors, libraries, dens, bedrooms,
sunrooms, recreation rooms, closets, hallways, laundry areas,
or similar rooms or areas shall be protected by any of
the means described in 210.12(A)(1) through (6):
