NJ is also a liberal hell hole, and in many respects just as F'd up as Cali.I have done jobs in sac and if you don't use a rotosplit you will need red hats .
In Fresno everything is arc fault . In Santa Rosa no arc fault in kitchen .
I have had AHJ call me on over fill in a 12 inch nipple . That aint NEC but they will call it in some towns . We all know they make crap up and for the most part you just go with it to pass and move on .
I have had inspectors in sac call me on box fill 20 CU in a 20 CU box with a blank . He want a 22 CU . Its his little rule and you getting passed until you do it .
For those of you that have not worked in this state it is f-up .
There are instances in which we know code doesn't require things that the inspectors want to see, and it's easier to just do them than make an enemy of the inspector. We all know that.
But this here is different. This is about someone openly lying to everyone here about crazy requirements actually being in written amendments. And how he won't spend the 20 seconds to show those amendments, but he will spend hours lying to us about them.
At some point the BS needs to stop.
