So?
I've asked before, so what if there is a parallel neutral path
between a meter base and a main disconnect?
What ifs aside, the requirement for an isolated neutral at a meter base has just become a thing the last couple of code cycles. So new in fact, they don't want to just come out and say all meter base shall have isolated neutrals just in case they overlooked something. So the utilities are making the call in Canada as far as I can tell. Prior to that, a solid connection at the meter base and a bond in the disconnect were the norm.
What were all the incidents and occurrences that happened back then? I've asked 3 different AHJs from 3 provinces and they all mumbled something about metal siding on a barn glowing red. Sounds like there was a real epidemic of issues with the parallel path setup.
