1 - 2 of 2 Posts
How do I wire one 4kw and one 5kw solar inverters togeather? This is a existing 4.9kw ground mount grid tie system with a Solectria inverter that is connected to a disconnect at the meter I want to add another 20 panels and a 5kw SMA sunny boy inverter, any suggestions on the best way to do this would be appreciated thanks Dan
Dan Anderson
You are correct I do have years of electrical experience but very little on PV systems that's why I'm asking stupid questions. This PV system is connected on the load side of the meter before the first disconnecting means.
1 - 2 of 2 Posts
