1 - 14 of 14 Posts
· Electron Factory.Worker
Iron core refers to what the windings are wrapped around in an electromagnetic device such as a motor, generator, transformer, reactor, inductor, etc. The iron core greatly increases the strength of the magnetic field and helps contain the field. When the core is something that's non magnetic such as plastic then its referred to as an air core.
· Donuts > Fried Eggs
And as far as iron conductors goes, iron has a high resistivity. It would take about six times the surface area of iron to equal the same current-carrying capacity as copper, so it ends up not being viable, especially given that it's just as heavy.
Add in the fact that it very readily oxidizes so all connections would have to be plated, it just doesn't make economic sense. UL489 actually specifically prohibits iron for current-carrying parts in breakers.
· Premium Member
Chemical Elements
Metal conductors in order of conductance:
Silver
Copper - Electron valence +1
Gold
Aluminum
Iron - Electron valence +2
Both elements have ; 2 electrons on the inner K shell, 8 on the L shell, 18 for cu on the M shell, and 14 for iron. Both elements have an incomplete unstable low number of electrons in the outermost valence shell, which makes good unstable electrons.
According to these rules you would think iron would be a very good conductor.
Actually according to their Atomic number, Copper is 29, and Iron is 26
1 - 14 of 14 Posts
