2017 code states.(Not permitted for Use as grounding electrodes) Metal underground gas piping systems.I have heard it... gas code requires that there isn't a bond on the meter and electrical code is that it must be bonded. I heard the same thing about a static arc. Basically if it's grounded the electrician was the last guy in there, if it isn't the gas guy.
That means that you can't use it to serve as the grounding electrode. It doesn't mean that you can't bond it the same as a grounding electrode would be bonded.2017 code states.(Not permitted for Use as grounding electrodes) Metal underground gas piping systems.
Has anyone heard this argument or does anyone agree with bonding of gas lines being a hazard?
I have a 6 in gas line running threw my yard and a tap running to my home. and it is not bonded at any place in my home. Most of the piping coming from the trunk is plastic.2017 code states.(Not permitted for Use as grounding electrodes) Metal underground gas piping systems.
