1 - 20 of 42 Posts
Say you go on a troubleshooting call for a fixture not working. You find knob and tube wiring and a bad switch. No big deal. The question comes in when the neutral is switched. What do you do? Suggest a rewire or change the switch out and collect your check?
Fixture isn't original...new one was wired with reverse polarity due to the neutral being switched...homeowner changes light bulb and gets shocked...you get sued because switched neutrals are now against code and as an EC you should have notified the customer/fixed the problem.
I don't see it as I used to. I would, at the very least, inform the customer of the potential danger and note it on the paperwork.
Deep Cover said:
Fixture isn't original...new one was wired with reverse polarity due to the neutral being switched...homeowner changes light bulb and gets shocked...you get sued because switched neutrals are now against code and as an EC you should have notified the customer/fixed the problem. I don't see it as I used to. I would, at the very least, inform the customer of the potential danger and note it on the paperwork.
This.
Make it safe and cover your ass.
The flipside is that they've had a switched neutral present for what, like 70 years? without an issue.
I agree with replacing the switch and GTFO.
You don't think some renter is just waiting to sue the first person they can? We do work near a college town and I can just imagine something like this happening.
Above scenario, you noted the possible issue on the paperwork, but the landlord wasn't present to sign for it. College kid changes a lamp while drunk/stoned...zap...you are served with papers.
I know, you can't eliminate any/all liability, but you have to try to minimize it.
So now we have a new fixture and stoned college kids. I don't think it matters whether the screwshell is hot or not if a drunk, stoned college kid is changing the lightbulb on his aluminum ladder in the bathtub. Dumbass should not have his finger in the socket anyway!
· Senile Member
Think of it like this: The faceplate on the switch may crack and break off, leaving exposed switch contacts that this time saved the tenant's life who touched them while standing naked in a pool of shower water on his bare concrete 80 year old floor, simply because you were wise enough to put the zero potential to ground neutral wires on the switch and put a protective wirenut on those pesky hot conductors....
· Head Grunt
What can you do really? You cannot force a rewire, you are not changing or modifying the wire/circuit? All you are doing is replacing a worn/damaged device. Replace the device, make recommendations, offer a bid/proposal and move on.
· Banned
You sound too scared or paranoid to be in business for yourself, you should go work for someone with bigger bawlz.
· Senile Member
option one. Don't do anything leave and let the liability fall on the craigslist guy.
option two. change switch collect your 50 bucks and worry that you might get sued
option three. change switch collect your 50 bucks and post on an internet forum the rest of the day
Option four: flip you van on its side on your way home from the switch job.
· IBEW L.U. 1852
Welcome back Cletis:thumbsup:
1 - 20 of 42 Posts
