Are these used in our trade, and if so, where? Why (what is a JFET's advantage over other transistors)?
For all power related applications, MOSFETs win over JFETs. MOSFETs have lower on resistance, and can handle way higher voltages and currents.JFETS are mostly obsolete replaced by mosfets. I don't know why anyone would still use them. Still didn't stop my teacher from doing a course on them though.
This might be the only purpose to ever use a JFET, but you'll probably only ever come across them in an OP-AMP package for specialized applications. Linear makes the LT1115 which still uses JFETS, but it's not suited for any low impedance driving sources. You'd probably use it to amplify signals from say a pH or a piezoelectric sensor. You wouldn't ever see them used in an audio application.JFETs are very good in low noise instrumentation applications and can do much better than bipolar transistors (BJTs) when their driving signals have high source impedances.
