1 - 7 of 7 Posts
The recent AFCI threads gave me the idea to take some pics of noise and such that is generated by a few items that I had in my lab. I was mainly interested in laptops and I looked at 3 different ones but the frequency and amplitude was nearly identical so there is just one pic of an IMB Thinkpad. The other laptops I looked at are an HP and a very old Toshiba Satellite running Windows 3.1.
This doohickey monitors the neutral or line and outputs the waveform to be viewed by a scope or spectrum analyzer.
Discussion Starter · #2 ·
This heat gun has a brushed motor and could be similar to a vacuum cleaner although the vacuum would most likely have a much higher level of noise. The first waveform is 100mv per division because I wanted to keep it the same as the laptop settings. The second pic is at 1 volt per division and the spikes are still larger than the display.
Just a little switching power supply similar to a wall wart. The bottom waveform is magnifying one of the noise bursts.
A "work in progress" switching power supply with not so good AC line filtering also on the 1 volt per division setting. The second pic is a much improved revision of the same model.
1 - 7 of 7 Posts
