never even heard of that, much less seen it
Its the drywall screw holding GFI breaker from closing due to fault !! These warranty companies sent by big builders are not qualified to do anything !! Period, not even oil a door hinge.😟While doing resale inspections on DR Horton homes in Georgia, I have found at least 6 of these attempted Stupid fixes. Homeowners state a warranty company was sent to fix breaker shutting off issue less than 1 year after new home possession. Any one else seen this illegal and dangerous "fix" in panels? This was from a 2019 inspection I failed. I can usually tell prior to removing panel cover someone's been in it by only having to remove 2 of the 6 cover plate screws, and finding the other 4 on floor.
HMM, I've testified in Court 4 times on criminal cases as an expert witness regarding Electricians operating without AHJ permits or Licenses and the home of customer that burned down due to them not following wiring basics in code book. In all cases the NEC 2017 was used to both prosecute and also used to sue individuals civilly for damages. If you fail to abide by it, I promise It will sink you to depths of Hell.I’ve never liked the word illegal when describing a code violation. The NEC is not a law that can be broken.
I was thinking the same thing. Internal trip . We've been over this issue before this from packing tape I think it was on the breaker handles trying to keep false early issue arc faults from tripping off every time Madge plugged in the vacuum cleaner. (or at least that was what Madge was saying caused it.......)The screw in the breaker will not prevent it from tripping but it will prevent it from being reset.
In another thread you tell us how you can qualify 500 companies in your state (in response to someone discussing qualifying someone in another state).HMM, I've testified in Court 4 times on criminal cases as an expert witness regarding Electricians operating without AHJ permits or Licenses and the home of customer that burned down due to them not following wiring basics in code book. In all cases the NEC 2017 was used to both prosecute and also used to sue individuals civilly for damages. If you fail to abide by it, I promise It will sink you to depths of Hell.
Here's a pic of most current lawsuit using NEC 2017 as evidence against an electrician doing side work with no permits.
He sounds like he just doesn’t like DR Horton.In another thread you tell us how you can qualify 500 companies in your state (in response to someone discussing qualifying someone in another state).
Maybe that fire was caused by someone qualifying too many companies and not having control of operations!
