1 - 20 of 32 Posts
felonious smile.
Just a question . Does it need to be gfci protected like bathrooms. If so can it get tagged off the counter outlets
GFI requirements do not mention toe kick heaters. Why would you think that they would need to be gfi? Even a receptacle outlet down in a toe kick in the kitchen does not need to be gfi protected unless it is a kitchen in a "not" a dwelling.
felonious smile.
It was directly under the sink base. I thought about leaky plumbing soaking it and the floor in front of it. So I tagged it off the counter circuit.
Bababoee
I just installed two and I ran a dedicated line for them . I would never tap off the kit recept... if its a 120 v unit it probably draws 6 amps at the least.... I would be pissed if I was that customer and my toaster is suddenly tripping on sunday morning...
The heater cannot be on the small appliance branch circuit. It is that simple. A kick space heater is a direct wired piece of equipment.
Reactions: sbrn33
Counter SA circuits can have clock outlets and chit that powers igniters/clocks for counter mounted stuff. That's about it. 210.52(B)(2)
Thumper
What is the brand and model number of the heater? Some can be run on 220.
What about the dishwasher/fridge/disposal circuits?
If it has an optional cordest or internal protection/thermestat bay you may have more options, depending on draw; most of the ones I do are hydronic.
Never put the toe kick heater in the sink base. You end up burning up the misses toes. It's the one location where you must stand for long periods in place and becomes quite uncomfortable. I've had to clip elements in them to lower the heat output so the women(HO) could wash dishes.
Lets all see if you can guess the one member here who has not hooked up a heater ever, even though I used to live in that extremely cold place otherwise known as Florida. I didn't even know they had "toe kick" heaters. That's kinda neat. I do know they got butt hole warmers built into toilet seats in Japan. Some of them play a tune for you also.
Reactions: Next72969
1 - 20 of 32 Posts
