Looking for a dedicated BX cutter. Other apprentices I have worked with that do a lot of BX rough-in have usually used the attached Klein cable cutters.
I don't like them. They're awkward, take up too much space in the tool belt, and just look goofy.
I've been checking out Knipex cutters and recently discovered NWS. Checked out lots of reviews but haven't seen any specifically mention cutting BX/MC.
Does anyone use NWS or Knipex that might weigh in on this? Another brand entirely?
Also attached photos of the "heavy duty" NWS cutter and a similar spring-opening Knipex.
Specs are about the same. Longer handle on the Knipex but 1mm larger opening on the NWS.
